silkk wrote:so 2 wires goes to the alt, 1 goes to the valve cover, and the last one goes to the manifold?
man.. do it for me!
It’s a little more complicated, I’m sorry if in my first post it’s not very clear.
There are 4 wires coming out of the main battery ground.
1 replaced the stock grounding wire
1 goes to chassis
1 goes to alternator from there, there is another wire going to the left side of the valve cover and from there to the left side of the manifold.
Last wire goes to the right side of the value cover and from there to the right side of the intake manifold.
I had an interesting discussion about this with my father who is a hardware/electronics designer, and he said that the most ideal grounding, is when you have one ground wire and each electrical component is connected to that wire, with an automotive engine that is impossible to do, so the next best thing will be multiple grounding points. I consulted with him before installing this, he said it will be best to reinforce existing grounding points and not so much create new once, so i did, I only crated 2 new grounding points, while reinforcing 5 others. I also saw that I needed to ground my transmission, but since I run out of wires, I’ll try to do that when I get a chance.
