tollboothwilley »
https://forums.nicoclub.com/tollboothwilley-u74535.html
Fri Apr 04, 2008 8:07 am
Ya, they are pretty straight forward. You really dont have to tear into anything at all really. You are just unscrewing a few bolts, putting a wire or 2 or 5 and then you tighten it back down.
With the ECU/TCU, you only have to pull off the kick plate under the glove box, it will snap out. And the kick panel to the right of that, has one plastic nut then will pull out from right to left. The door kick trim, that just pulls off as well. And last, the glove box, 4 screws up top, and one on the bottom left i believe, maybe another on the bottom right. Thats it.
Take pics when you get to them if you have issues, and i'll point ya in the right direction.
