Ground wires smoking, need wiring diagram
IDriveFords
Car: 93' Nissan 240sx
Where can I get a wiring diagram for an s13 with an sr20det? I remember a site called something like cameltowing or something like that that had diagrams but i cant remember if it had sr20det diagrams. The motor is a fresh swap and it wont start and now when I crank it some of the ground wires start to smoke so I stopped messing with it for fear of melting the harness. I need a diagram to figure out whats missing or isnt properly hooked up unless someone here knows. Thnx
Steve Lloyd
Hope this helps.............
BLKTOPS14SR
Car: 1998 Nissan 240SX SE Kouki
1971 Buick Skylark 455Buick big block
1970 Cutlass Holiday Coupe
2002 Ford F-150 XLT
1972 Chevy Cheyenne
I'm having the same problem with my redtop in my S14. I used sr20 hybrid and camel towing diagrams.
IDriveFords
did you figure out what was causing it? thnx for the diagram steve I'll try to figure it out tonight, thnx again.
BLKTOPS14SR
2002 Ford F-150 XLT
1972 Chevy Cheyenne
Not yet!?
Blown240sx
Car: 1996 240sx
We offer wiring service for 100-150 if your interested and we will guarentee the work.
Email me if interested.
[email protected]
BLKTOPS14SR
2002 Ford F-150 XLT
1972 Chevy Cheyenne
Could you do it if it has already been cut? Extremely interested.
Blown240sx
Car: 1996 240sx
depends on what has been cut? If your talking a cut off harness probably not since finding the missing plugs would be a b*tch but we can repair harnesses that are just cut up but all parts are accounted for. We also have one spair SR harness un modded here for 200. 150 for modification so 350 for a modded drop in harness.
BLKTOPS14SR
2002 Ford F-150 XLT
1972 Chevy Cheyenne
Blown240, emailed ya with info.
sr24084
Car: 240sx
What kind of grounds are you using? Try grounding the motor in three locations with some decent wire. Asuming everything is wired correctly.
