the ground for the injectors comes individually from the ecm. ie the ecm supplies ground when it wants injector on.Miller White wrote:i have been lookin for a way to put new ground wires on my car. i put a new one from the exhaust side to the fire wall but was wonderin where every one is puttin theirs. also does anyone know any specifics on how to ground each injector individually?
look up ground in tutorial link in my signature . im really sorry that you shared your idea. really sorry.Miller White wrote:wat i've been thinkin about doin is takin the wire that goes from the negative terminal to the block and disconnectin it and runnin it instead to a metal plate then runnin ground wires from the plate to dif spots on the block. its kinda confusin but i think it might work
not as well as the engine block. use a multimeter . your grounds are probably fine as they are.Miller White wrote:well like i said i replaced the one on the exhaust side. would the idea of the plate not work
