Ground wire kit install
awdjdmtalon
Car: 04 G35 Coupe, Diamond Grafite Metalic, Aero package, 6MT
Ok I have tryed to search this topic, but have not found a write up on it. I have a ground wire kit that I have had for a while. (Not application specific to any car.)
Is there a write up w/ pics on installing one. Or at least good clear pics of where they are connected on the eng. and chassis?
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
keep searching, you should be able to find plenty of info, It's pretty simple, you're just basically conecting the battery ground to several points on the engine, frame, transmission, ECU, etc.
Good Luck
CYO44Baseball32
Car: G37S 6MT
awdjdmtalon
Thanks for the link. I'm guessing the G35's should look the same, minus the 2nd wire for the 2nd t-body.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
i know that I have posted a pic/short write up of what i did before...
this should help you a bit, ask if you have other questions but there are other threads about this...
