Ground in trunk
JoshH
Car: Nissan Versa S 2007
Subaru BRZ 2013
I know that some people here installed amps/woofers in their trunks. I just wanted to know where exactly did you connect the ground cable? My dad does not want me drilling holes in my car, but if there is no place where I can ground decently, then I guess I'll have to.
lain
Car: 2007 Nissan Versa S
there might be something under the carpet in the trunk...like a bolt or screw or something...i did the samething to my 240sx but i didnt really care about the car so i just ripped the carpet off. other then that i would say to run another wire to the hood...there should be plenty of places to ground it there. or search google...im sure there is plenty there too.
JoshH
Subaru BRZ 2013
I know of a bolt in the trunk which holds down the rear seats. Would it be alright to take off the paint and ground it here?
NOreasonY
hey,
I had the same problem finding a good ground and i ended finding a good one. If u flip left hand portion f the back seat forward (assuming ur mounting the sub on the drivers side) you theres a hold in a bracket ( i think its what connects the seat to the car you can use..i just got a nut and bolt and sanded away the paint with the dremel and it works great..It might be a little tricky getting the nut or bolt to tighten down (youll see what i mean ) but its do able. I wish i had more detials but i did it a while ago and i forget exactly... but check it out ..it should work fine.
JoshH
Subaru BRZ 2013
Thanks for the reply.
I'll look at whatever I can find. I am most likely setting up the amps on the right (passenger) side of the trunk and the sub on the left side.
