Huh? The type of strut you use has no bearing on whether or not your suspension is negatively affected by over-lowering. You will get too much camber and you will **** up your suspension geometry regardless of the type of shock you use.Chingon wrote: If you have to use them i'd say pair them up w/some konis because they are not affected negatively when lowered
