Gross Polluter!
theronin
Well, it being that time for my 240 i took her to get smogged. well was i surprised when the printout came back!
heres the numbers.
hcmax 89 measured 381
comax.50 measured 10.26
everything else was fine.
anyone have any suggestions for me? he said timing was dead on also!? thanks for any advice you can spare a gross polluter LOL
Sliding_S14
Car: Sliding from the Side
damn, my hc was 8 and my co was 0.00
dima
Car: my wife, cars, linux
Man, you are running too rich.coud be a lot of things gone bad
lessthanjakejohn
do you have a cat?
dima
How many miles on it?
deftdrummer
Car: cars, drums, music, technology
i would hate to see my engine smogged :-X
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
wish i lived in one of those areas where you don't need to get checked
theronin
the car is stock it has 116k miles
erich
My $.02: Bad O2 sensor.
flyfishz
Car: fishing, golf, hangin with the kids
I just got through living your nightmaare...Being labled gross polluter in Cali is a kiss of death because ther are limited stations that can pass gross polluters That said, here is my path that included many wrong and expensive turns...
First advice--"replace the O2 sensor and you should be good to pass... maybe a new CAT..." Replaced CAT, O2 sensor, plugs, rotor and cap... Failed worse...
Second advise... "must need to clean your injectors and throttle body...I can do that for ya..."-- failed again
Third times a charm right..." what ya got here are defective electrical conections on your ingectors--- passed smog but failed visual as the check engine light came on
Fourth time---"you must have a short... may take a while to find it..." cleaned all conections from the wiring harness--- Failed cause I had 17" wheels that threw off the new Cali smog dyno
Fifth attempt--replaced stock wheels on rear for the test... Passed with flying colors...
Best of luck with your car... hope you do beter than I did... but now I am good for two years...
theronin
um, i think he was bsin you about limited stations not being able to pass gross polluters. i think its my cat, o2 sensor is less than 3 months old but keep the ideas coming guys
droptopsilvia
a CAT should solve it, I failed on everything but one I got my catco cat put on I passed in HC and CO but not NOx still trying to figure it out.
