Gross Noise
1.8TS13
Car: ca18 swapped s13
My CA S13 has had no problems for the last few months, then out of no where i started it up one morning to this odd sound from under the hood. The sound is slightly evident under idle, and gets more loud as boost comes on. It's some sort of grind/shreak sound. I'm checking the turbo today for shaft play, but if anyone else has any ideas it would be greatly appreciated!Thx
bone_stock_240
Car: 1995 Infiniti Q45
Maybe it is coming from one of your belts?
Zero260
Car: 91 240sx coupe
grind/shriek like metal scraping metal? that increasing during boost? definitely check your turbo, but I had one that made that noise from the turbine side.
driftin8ez
Car: 92 Coupe, Turbo Miata
Did a small animal crawl into your engine bay and get chopped up by the belts?
