Groaning in reverse.
theother1wstolen
Car: 92 240sx Coupe SE
Just what the title says, i have a groaning in reverse, not ALWAYS it started out only doing in first thing in the morning, and now its getting more and more constant, is it just my bad brakes, or a wheel bearing? any way to tell?
engineperson
Car: 91' Nissan 240sx coupe Ka24De
i think most rear wheel drive cars do this, but what im thinking of is a whine. mine always does it.. I did have i guess something like a groan and clunk sound every once and a while. I think the whine might be the diff. but i think the groaning clunk was from the brakes. if its not too bad i'd drive in reverse for a while w/ someone out side listening to it, maybe you can pin point it that way. I never worried about mine, but yours sounds possibly worse. good luck
ANVIL
Car: RB25DET S13.5
check the drive shaft to see if it has any play or is loose, could be the joints
spindrift187
Replace rear brake pads, thank me later
Lost_In_Translation
Car: 1991 Nissan 240sx, stock with many problems.
Next time it's making the noise try pulling the handbrake up and see if the noise goes.If it does check the rear brake shims, the ones on my car were bad so it made a groaning sound in reverse cause the pads moved to an angle.
Or the brake pads could be very bad...but I changed the ones in my car a couple of times and it didn't help.
