Gripforce stage 2 clutch
freakyjason
Car: 1990 240sx
hey guys! i just finished the break-in period on my new gripforce stage 2 clutch. it doesnt seem too different from stock. also it slipped really bad up until about 490 miles. then i adjusted the pedal linkage (against my better judgement but i was getting frustrated) and it seemed to grip okay. now at about 680 miles, im beggining to beat on it a little bit but when i dump it into 4th gear (and sometimes third) it slips and i can smell the clutch burning. i also had the master cylinder changed with the clutch because it was leaking a little bit. i also had a fidanza flywheel installed (i dont know if that has anything to do with it). also, i did not do the labor myself because of lack of space and time. instead my local mechanic did it. what do you guys think?
Florida240sx
I first started to say flywheel but you got a brand new one...Is it a true fidanza? On my RPS turbo clutch I couldn't wait. Drove it for 100miles before I started to have fun.Held just fine.Thik it slipped once but because it was hot.
freakyjason
Car: 1990 240sx
its a real fidanza alright! what do you think?
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
Well that depends...Never heard of gripforce being a good company.Secondly I purchased a fidanza and a Compotition 6puck clutch sprung.The clutch that I purchased almost took 800miles to break in properlly, works good and skirts in third gear sometimes.I would wait just a little bit longer before getting your hopes up.......Did you replace the entire clutch assembly?????
freakyjason
Car: 1990 240sx
if by the entire clutch assembly you mean the throwout bearing, disk pressure plate and pilot bushing then yes i did.
freakyjason
Car: 1990 240sx
i just realized something today. there is some liquid under my car in the driveway. could any of this have something to do with a leaky master cylinder or hydrolic line? i guess ill take a look at it and see if that really is what it is.
Modified by freakyjason at 5:33 PM 1/28/2006
ORL240
Car: 1995 Nissan 240sx
Bleed ur master cylinder before you spend ne more $$$. Ur mech. should have but just in case.
