gringing noise when clutch pedal depressed, lights dim
pufutz
1994 Altima 5 speed manual.Had the radiator and belts replaced then wanted to drive car home after hours, when depressing the clutch pedall all the way there is a starter like noise while engine is running and headlights dim, I can change gears, less the grinding noise,with the pedal half way depressed - when fully depressed the noise kicks in and disapears once the pedal is released - could it be some miswiring of the starter/clutch pedal interlock switch form when they replaced the belts or radiator?Thank you!
ragenasian
Car: AE86 w/CA18DET
You do know this is the CA18DE/CA18DET motor section right?
pufutz
Sorry, wrong forum !
zero_gripS13
Car: soon to be 95 s14 hopefully
locked up throwout bearing keep driving it yourlll saw through ur cluck fingers.. seen it happen.
