GhostRider240sx »
https://forums.nicoclub.com/ghostrider240sx-u13109.html
Sat Aug 14, 2004 7:04 pm
OK here is the problem, I can drive fine mostly. Sometimes when i drive second gear grinds!!?! Then once in a while when i press the clutch pedal i can't get into any gears. It sounds like the transmission is grinding or locked when i press in the clutch. My A/C does not work. When you turn it on only warm air blows and only from the feet, no matter what settings it is on.
