Grinding starter?
nissantuner91
Car: 1991 Nissan 240sx
Alright guys i keep getting this problem with my car somehow my starter keeps getting grinded. Check out the pic. It started happening after I did a stock motor swap. I would really appreciate all the help. And i've used the search button already.
<center></center>
nissantuner91
Bump. Any Suggestions?
Silvia007
Car: 93 Nissan 240SX SE Fastback
I'd check the flywheel.
nissantuner91
Thanks for the suggestion. Any more?
mutiny
Car: 1989 240SX
what other suggestions can you get.... the starter turns the flywheel, its the only thing it touches, obviously its either a problem with the flywheel or the starter.
RunCool
Your one way clutch in the starter is shot or you have a "weak" holding winding in the starter solenoid
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
Go to your local parts store and buy a starter shim set. Start with a small .20 shim between the starter and the block and go bigger if it still occurs.
I think your problem is the starter is not fully disingaging after the car starts, and your starter is still running against the flywheel. That happens when the starter housing moves or flexes possible gets bent. The shims will take care of the clearance problems.
