Grinding sound when accelerating
lvdisturbed1
Car: 1990 Nissan 300zx Twin Turbo
Lately I've been getting a grinding noise from transmission when I am accelerating. There is no grind when I actually shift, so I wouldnt think it is the syncros. It happens when I am in gear and give it some gas. First, second, and third are where I have the issue. Fourth and fifth drive fine. Clutch going bad? Gears maybe shot? Any ideas would be great.
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Welcome to Nico. I'm no transmission expert, but have you tried a fluid flush?
Moving to Technical Forum.
ZL8NING
Car: 1993 300zx 2+2
Fluid "flush", or just a fluid change.
I believe I've read somewhere that a flush wil eventually toast a transmission.
lvdisturbed1
No I haven't. I'll buy some redline mt-90 and see if it does anything.
Ziggy1621
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
ZL8NING wrote:Fluid "flush", or just a fluid change.
No, if it is slipping, it will slip more with fresh fluid. But he is grinding, so that's why I recommend it
Metacom
Car: 1994 300ZX TT
There were reports of early Z32s back in the 90s making a grinding noise in the higher gears, you can read more about it here: http://www.fairladyz32.com/downloads/im ... /atozx.pdf
search "grind" in the PDF and read that section.
I get a grind in 2nd and 3rd when my clutch to gas pedal ratio is anything but "perfect." Pretty sure its my clutch itself as the noise only happens at engagement and shortly after.
