AmoebAssassin »
https://forums.nicoclub.com/amoebassassin-u22213.html
Thu Jul 06, 2006 5:28 pm
Dan,
If the a$$ wont tack weld it, take the strut off, go to home depot and get some stuff called "JB Weld." Clean the stud and the upper mount up really nice (use rubbing alcohol and soap and water, the more powerful the detergent the better). Once clean, rough up the bottom of the upper mount with heavy grit sand paper. Clean it again. Mix the JB Weld and apply it to the flange on the bottom of the stud, and try to get it lined up straight so that the bumps on the flange set into the recesses in the upper mount (look closely, you'll see what i'm talking about). Clamp the bolt in place and let it set. Reinstall the strut. If done properly, the JB weld should give you enough torque resistance that you can tighten the bolt down enough to pull the stud back into the upper mount.
