Maverick7687 »
https://forums.nicoclub.com/maverick7687-u17139.html
Wed Jan 04, 2006 5:18 am
Thanks guys. I am not sure about the injectors but I did check the fog lights last night. I took the relay out, replaced the fuse, nothing. So I put the relay back in and unhooked both lights. Turned on the switch and the relay clicked, fuse stayed intact. Replaced lights one at a time and now they are both hooked back up and working fine. I have no idea what was causing that but whatever it was its not doing it now. As for the sound, I know what you mean about having to actually hear it but just for the hell of it I will try to explain it. If you have ever stook outside a 240sx with a KA24DE with the hood open while the engine is running you have undoubtedly heard the infamous Timing chain guide rattle. Its like that but about 3 times louder and on the inside of the car, you cant hear it outside. It usually will not make the noise when you are accellerating but it gets loud on decel. That kind of makes me thing that maybe there is something rubbing on the back side of the motor when it turns from letting off the gas? Then again that wouldnt make much sense since it only does it for a few minutes after startup. I can try to get a sound clip if you think it would help. I just want to get it to stop, its annoying. Like I said beforem, nothing changes when it is making the noise and everything else runs fine. Just an annoying sound. Thanks
