Nickcastro »
https://forums.nicoclub.com/nickcastro-u96964.html
Sun Jul 20, 2008 11:53 am
It grinds when its in neutral and when i push the clutch in it stops. When i dropped the transmission i took all the pieces apart in the bell housing and then put it back together correctly. When i start up the car, after barely putting the transmission in, it doesn't grind. but as soon as i push the clutch in and then let it out it the T.B. grinds and it doesn't stop until i push the clutch in. Could it be that maybe i have the wrong clutch?
Modified by Nickcastro at 3:06 PM 7/20/2008
