Grinding in front left wheel when turning left M35X
joemean
Car: 2006 M35X
Hey, I am trying to diagnose some suspension and possibly bearing issues. I have some grinding when going under a little speed and turning the wheel about a quarter turn to the left. I am assuming wheel bearing, but don't want to get the wheel off to confirm if it is something else. I also have vibration when braking. It really sounds like it is from the drivers side, but the instructions I have seen here would lead me to believe if the sound happens when turning left then it is the right bearing.
Ilya
Make sure you don't have any issues with your calipers/pads/heat shields...then move on to shaking the wheel (when car is elevated) left to right, up and down, etc. to see if there is play.
joemean
Car: 2006 M35X
Hey, I tried the wiggle top bottom, left and right and I did actually have a lot of play left and right even though one wheel was on the ground. This was the case with both front wheels. I didn't check the brakes yet though, I will do that tomorrow night.
joemean
Car: 2006 M35X
Thanks Ilya, i think it was the heat shields around the back of the rotors that rubbed the back of the rotor on hard turns. I think the rotors are little "warped" even though I read an article on here of the myth of warping.
