Grinding from Rear end during low speed turns
disallow
Car: 2010 Nissan Rogue SL AWD - 110000 km
2005 Nissan Pathfinder SE Premium 4x4 - 270000km
Hey everyone.
So after some reading, it sounds like I have the dreaded NTB 10-029 issue, grinding from rear during low speed turns.
I looked up the fix for it, and looks like well over $1000 in parts!
Anyone have any experience with this here? Should I check anything first? I don't have any lights on the dash. But they do all work, and I am certain that the AWD is also working.
Like if checking the electrical connector would help, make lubricating it. Not sure what else, I sure as heck don't want to replace the Electrical Coupling Assembly... Looks like you might as well replace the whole rear end!
Thanks
t
lexcrob
Car: I get a different ride faster than I could update this.
Sounds like a new rear end is the solution. Maybe talk to someone who works at a dealer as a mechanic. They might do it as a side gig for you. If I have a problem like that I normally just park around back and just walk in the back and talk to the mechanics. Skip the retards up front.
disallow
For now I have unplugged the connector going to the Electrical Coupling. This deactivates the AWD system, which I don't really need in Summer time anyways. At least this will give me some time to see what I want to do about it. I made an appointment at the Nissan Dealer, but they want to charge an hour's labor ($135) just to look at it.
NOS1234
Car: 2014 Nissan Rogue S AWD
If it is louder with turning in one direction than it is when turning in the other it could be a bad wheel bearing. Just a thought.
disallow
Update on this thread. I've been driving with my coupler unplugged for about 2-3 months now, but winter is approaching!
After trying to find cheaper couplers (they go for $950 US), I think the less expensive alternative is going to actually be to replace the rear end. I've found a couple local low km rear differentials for about $500. Looks like all years are compatible, and if I go with a 2011 or 2012, maybe I'll get lucky and it'll have an updated coupler in it.
Thoughts?
t
disallow
well I've found a used differential from the local scrap yard. $400 for a carrier from a 2010 Rogue SL with 84k kms on it (52k miles).
Need to decide it I want to take a chance with it. I was hoping to find one from a 2012 or newer, as I would wonder if the newer diffs have an updated electrical coupler in them. But I'm just guessing.
Any thoughts on this? If its not a commonly failing part, maybe I should just go for this 2010.
Note that I haven't been able to find the coupler anywhere for less that $1k USD.
Winter is coming and I want my AWD back!
Return to “Rogue Forum”
