evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Jan 03, 2007 6:55 pm
are you bringing the revs up as you down shift? sounds like a syncro problem, likely got jamed in too many times on the upshift, but if you can't live with it it's a costly rebuild as they'll beed to inspect andmeasure every part to ensure they fix the problem, or maybe you cna find a use dtrans from a total cheap, and if you havn't already try running a full synnthetic gear oil and see if it improves
as for the gas pedal, it's drive by wire and that scares me, you might want to have the codes read by a tech
