Volkswagen had a feature that required you to turn the ignition key to the full OFF position before you could attempt a re-start.
A VW Golf I learned to drive stick shift on had this feature... nothing worse than stalling at an intersection then frantically trying to restart the motor. It took me 1-2 minutes and I was the recipient of much horn honking from disgruntled motorists before I figured out I needed to turn the key back to OFF before restarting.
