Grille Clips
General discussion area for the U13-chassis Altima
97Altima_Guy09
Car: 1997 Nissan Altima GXE Limited Edition
So How do you guys put grille clips on the 97 Altima grille I put them in right but it won't click when I put the grille in place on the car. Tried to make the clip go in further but to no avail used alot of force but doesn't work. How do you guys do it?
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
sure they're not broken? you put the clips into the grille first, then it snaps in very easily.the first few times you take the clips out will have you cursing. a long fairly skinny slot screwdriver works best. you are 'turning' the clip about 30 degrees, and it should come free with gentle pull. have to do same at each clip in turn.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Lots of swearing usually works to get them back into the grille. It's all about twisting the head so the arms pop back into the slots.
Return to “1st Generation Altima Sedan (1993-1997)”
