sound like you have a bad fan clutch for your overheating problem ,thats if you are using the stock fanTwiztid_S13 wrote:ive replaced alot of stuff on it.. when i first got it i replaced the water pump and timing belt.. i didnt have the knock sensor hooked up and blow the turbo cuz it was running too rich.. so i connected the knock sensor and rechecked the timing and got another turbo now .. then it was overheating.. so i replaced the head gasket with a tomei .. flushed the system and got another radiator and got a used turbo from t88lexus which is working wonderfully.. but the car is still overheating.. i replaced cap ive installed better electric fans.. but the radiator was for a sr.. so the upper radiator hose is rigged to reach the engine.. well i removed the thermostat and put a new one.. still overheats when u take it out on the road.. so i removed it.. and now it gets up to 3/4 and cools back to normal as long as im on the highway.. but if i come to a stop it starts slowly getting hot.. so i think i need to get either the proper radiator and put the shroud back in and fan.. or get a bigger radiator and twin flex-lite fans.. so ive got the problem solved but need more cash ... but heres the other problem.. the car has trouble starting up sometimes.. but once its on itll idle normal.. but sometimes itll just die.. and i cant it to start back up again.. it seems like it gets flooded.. but then again i think my stock crap fuel pump may not be giving enough fuel wnd gets air bubbles or its just giving out.. so im gonna save up and get a fuel pump now and go from there.. so should i get a wahlboro or just get one of a tt 300zx? and ive replaced the plugs again.. i think i bought the wrong ones last time.. but now i got some for a 200sx ca18et.. exhaust side.. but still acting strange.. and my ignition system is throwing spark.. but i think i need a better altenator.. the electric system seems weak and u can hear a electric noise via the speakers... heh.. i feel better today.. just got a lil agitated last night.. i just miss my car im tired of bumming rides heh
you didnt blow a turbo cause it ran rich you blew a turbo cause its 14+ years old and from a junkyard...Twiztid_S13 wrote:ive replaced alot of stuff on it.. when i first got it i replaced the water pump and timing belt.. i didnt have the knock sensor hooked up and blow the turbo cuz it was running too rich.. so i connected the knock sensor and rechecked the timing and got another turbo now .. then it was overheating.. so i replaced the head gasket with a tomei .. flushed the system and got another radiator and got a used turbo from t88lexus which is working wonderfully.. but the car is still overheating.. i replaced cap ive installed better electric fans.. but the radiator was for a sr.. so the upper radiator hose is rigged to reach the engine.. well i removed the thermostat and put a new one.. still overheats when u take it out on the road.. so i removed it.. and now it gets up to 3/4 and cools back to normal as long as im on the highway.. but if i come to a stop it starts slowly getting hot.. so i think i need to get either the proper radiator and put the shroud back in and fan.. or get a bigger radiator and twin flex-lite fans.. so ive got the problem solved but need more cash ... but heres the other problem.. the car has trouble starting up sometimes.. but once its on itll idle normal.. but sometimes itll just die.. and i cant it to start back up again.. it seems like it gets flooded.. but then again i think my stock crap fuel pump may not be giving enough fuel wnd gets air bubbles or its just giving out.. so im gonna save up and get a fuel pump now and go from there.. so should i get a wahlboro or just get one of a tt 300zx? and ive replaced the plugs again.. i think i bought the wrong ones last time.. but now i got some for a 200sx ca18et.. exhaust side.. but still acting strange.. and my ignition system is throwing spark.. but i think i need a better altenator.. the electric system seems weak and u can hear a electric noise via the speakers... heh.. i feel better today.. just got a lil agitated last night.. i just miss my car im tired of bumming rides heh
The car nor the engine is not your worst investment, but I do caution all about buying anything from ebay. Most people selling these motors know nothing about them and are just interested in getting rid of them to some unsuspecting fool. As with your case, you bought your motor off ebay from a friend of mine, but he's a Toyota person and his knowledge about this motor is about as limited as your immediate financial situation.Twiztid_S13 wrote:My worst investment is this whole f*cking car and this pos ca.. sorry i need to vent ive already spend about as much as needed for a damn sr on this ca and im not getting anywhere.. so im just gonna think about it for the next few months and decide whether to even bother anymore or just look for another project s13 and take a shotgun to this one.. i swear this car is cursed ... oh and my advice to anyone looking into a engine swap is buy a good clip from a reliable source dont trust any ebay crap.. itll be worth it in the end just cuz its cheap doesnt make it a bargain... like that saying goes .."you can shine a piece of **** up.. but its still a piece of ****".. damn i feel better.. and sorry for cursing
were can you get a walbro for 75 $thankssorry for the off topic so...NeedCAforS13 wrote:excellent points!
these are problems alot of us have had, but it seems like you went about it all wrong. when I was overheating, I went out and got a bigger radiator, not a $300 headgasket! it also sounds like your radiator is a ghetto rigged SR one, which would be another reason to get a good KA/CA one to replace it.
your idle problems are regular CA problems. the idle air system SUCKS. you want your car to idle well, go buy new sensors (idle air, air regulator, etc...) they're not cheap, but they do work (my car idles awesome now).
the fuel issue could be something as simple as a bad FPR. but YES get a walbro. think of it as cheap insurance. covers your multi thousand dollar investment for $75. seems like a no-brainer to me.
sounds to me like you should sell some of your aftermarket stuff off the car, and get it running WELL on stock stuff first. thats the best way to do things in my opinion
Best of luck to you man, and don't give up! I've been loving every minute of my car recently especially with the drop in temperatures here in FL from 90's to 40's. you wouldn't believe what a 50 degree drop in intake temps do for response and power!
Sean
I'm skeptical about the use of lower-than-stock-temp thermostats. I don't see what difference it makes. All it changes is the temp that water/coolant enters the radiator. I see how it would help if you started running hard before the thremostat opened, so when it did open it wouldn't spike as high. However, it seems to me that the engine may have a hard time reaching operating temperature if the thermostat opens at 75 C rather than 82 C for example.sdtouge wrote:
did you bleed the cooling system?your gauge could be inacurate, samething that you are describing happened to me. try and take a thermometer and read what your coolant temp in the radiator ids (turn it on and let it warm up with the cap off) if its under 200 farenheit, your gauge is faulty.
yes i know 200 is warm but i just gave a nice number. my ka averaged about 175. so i would say anything under 180 (depending on what temp thermosat you have) would be good.
what thermostat did you replace it with? sure its 50 more dollars but i highly recomned the nismo espicially if you drive hard for more than 30 sec.
hope this helps!
