NO!!! That fitting IAP gives you leaks. Greg's is leaking and is going to weld a new one in. Just take the pan off and have it welded.DRIFTEADOR wrote:yeah, its been discussed before and iirc IAP's kit doesn't require removal of the pan. Use a grease coated bit, drill slow, and wipe the shavings often.
