jdansmith wrote: I found this posted on a auto forum, don't know if it will help.for all you folks that have a nissan that runs and dies check the ignition coil mounting bracket to see if you have a transistor control module mounted on it it could be a 2 or 1 plug module they work thru your computer and will cause ignition problems when bad, new cost from $115 at auto parts stores to over $200 at a dealer i replaced 3 already solved the problems of running and dying
ill do another check on the relay connections and pull the intire underdash harness out...but im thinking of buying another harness and a spankin new dizzy just to rule out those..wouldn't mind a new dizzy anyways...thanks for the imput.OutToWinPAHC wrote:There are two relay foxed under the hood, and one 3 relays that would affect it. ECCS, Fuel pump on the pass isde, and accessory relay 2 on the drivers. Under the dash are more relays, the ignition relay and accessory relay. (drivers side)
I would think a loose connections, relay or device going open.
There are also interlock relays, and inhibit relays. Check the FSM EL section for starting system, and then harness layout.
thanks man...but tested that when it happens and i get power to the ignition wire (black w/white stripe) kinda faded but looks white..anyways..thats not the culprit for shur...i am however planning a push button mod to get rid of that anyways in the future..as im going to install a (IdidIt) brand aluminum steering column....cant wait for the cash for this mod...its really gona set off the inside of the car...but i do thank you for your imput aswell.KennyV wrote:ign switch maybe?
ney sire...no alarm here...and i run an external inline aromotive fuel pump...with its own system electricly..thanks for the try thou.blackandblue wrote:Do you have an aftermarket alarm that has starter and fuel pump disable? An alarm that tries to arm itself with the ignition on may be cuttin' your ignition power and fuel. Just a thought.
