Greetings one and all!
Packrat182
Greetings, my name is Packrat and I hail from http://www.nissanexa.comI drive a Kn13 pulsar with the ca18de under the hood. I am about to go through the ca18det swap for this thing and came across this website as i searched google.I am here for pointers, tips, and any other funitude that may come about :-DU guys have any pulsar drivers on this forum?I want to get the ca18det with the top mount intercooler from the u12 to drop into my car. As i have never messed about with turbo's before does anyone have any good pointers, tech tips, equipment, etc...about owning/tuning a turbo ca?Just so you know i built this car, so i do know my way around the DE motor.thanks in advance,Rat
Bwana
Car: Denali
Welcome!
Read up on the info in the sticky threads at the top of the page, that should get you started! We do have some knowledgeable Pulsar owners here, I'm sure they'll chime in.
float_6969
It should be a relatively straight forward swap. You might need to do some minor wiring and a little exhaust work, but since your existing chassis has got a CA18DE in it, you should be basically good to go.
Then only thing I'd be worried about is that top-mount with your stock, scoop-less, hood. You won't be getting any airflow to that intercooler with the stock hood, so I'd recommend either getting a hood with a scoop, or going to a FMIC.
DrIft Ready
Car: 1990 silvia built sr..
Welcom to the best place on earth
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
hey packrat! I know you, dont you live in PA somewheres? I use this same name at nissanexa.com so we're not out of place
anyway, good to see another US exa member over here.
boost_boy
Welcome to NICO "Packrat182" ,
I too am a member on http://www.nissanexa.com, but i haven't done much posting in years on that forum. I don't quite own a pulsar, but I do own a B12 sentra which shares nearly the same chasis with the pulsar, if that helps a bit. It's good that your knowledge of the DE is sufficient because the same techniques can be applied to the DET as well.
I also started out with an AWD CA18DET w/TMIC and let me just tell you that thing is worhtless. If your engine set does not come with a harness and ecu, then you have several options. You can either have your DET computer done by Jim wolf technology, you can use and S13 CA18DET sylvia/180sx/200sx harness and ecu (if you know what you're doing), or you can simply go standalone engine management which is by far the most flexible and trouble-free way, but to some that maybe argumentative.
You can use your KN13 mounts, but you will eat them up like you would do ice cream as they are not strong enough to constantly support the added torque. You can use your stock CA18DE transmission and axles as well as your flywheel, but you will have to upgrade the clutch system. It is very imporant that you put the necessary gauges on the vehicle to monitor critical engine component functions such as boost gauge, oil pressure gauge, and even a fuel pressure gauge.
You will definitely need to upgrade your fuel pump. A walbro unit for an S13 chasis will do just fine. As for any upgrades, there's tons of information here on this forum, so you search til your heart's content. The biggest thing on this forum as opposed to most is that whatever you're looking for or need to know, has more than likely been covered. So again, welcome to NICO and hopefully we can help you get to where you want to be.
Dee
Devils
Car: Nissan KN13 EXA & S13 & B13 NX-R Coupe.
Hey Rat how you doing...
Devils shouting out from nissanexa.com too!
I had a B12 Sunny ZX when i was in UK!!!
Packrat182
yay, ppl i know! ok yeah i have a hood scoop coming from a friend from nissanexa.com...u guys get my msn info from the info tab at the club and lets chat over IM. good to see you again boost boy, you two devils and neon k?rat
Liquid_Neon
haha, devils too? is the exaboard gonna hop over here or something?
next ill see android popping up.
float_6969
The more the merrier! I'd love to have a stronger N12/B12 influence over here!
nismoplsr
Hey dude!
These guys brought up a few things i forgot to tell you about.
One being the fuel pump. Other than an s13 pump a Z32 TT pump will work to and can support 500+hp of fuel flow.
Filling the motor mounts with 3M window weld is a quick easy solution that works just as good as expensive poly mounts.
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
Devils wrote:Hey Rat how you doing...
Bout time you came over here now you know where i get all my info from
Packrat182
haha wth ive been a member of nissanexa.com for like eons and you guys never told me about this place....for SHAME!!!!hahaok so anyone know where i can get a front clip from a u12 ca18det fwd?rat
