Green Relays
skillzilla
Well, I asked inside another thread, bnut didnt get an answer, so here goes:
I dont have the green relays, I have the plugs on the RB20 harness, but not the actual relays themselves. Is there anything I can do to get my car to run? Did any USDM cars come with these relays? This is really a bummer, with my project being halted by little green boxes.
Thanks,
JJ
skillzilla
OK, I just did some more searching, will try to find the relays in my car or on my old KA harness. Sorry for my n00bishness of not searching thoroughly.
goofynick6
Car: 1995 S14.5 RB20DET
Yeah, I'd say a relay is a relay as long as they're the same amp rating or however relays are rated.
Nick
Wulfgang
Those two relays provide power to the MAF, CAS, coils, and a few other things. Just about any relay from your KA (or maybe some unused relays from your clip) will be able to handle the current.
skillzilla
I ended up pulling two from the KA fuse box that werent used (I hope) and using those, we'll see if it works.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Go to Autozone and have them look up a Relay for a 300zx and all the relays should be the same but here's the part numberIt's a "GP Sorensen" Part # 41-5021 here's theSKU# "7 45321 03962 8" Mostly Nissan uses the same relay for multiple things cause it comes up for Fuel pump and electronic Fuel injection and something else.Hope it helps
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Awesome info... thanks Sil240!
Sil240
No problem should i post it up in the Sticky Part # thread??
