xekushnr »
https://forums.nicoclub.com/xekushnr-u16901.html
Mon Jul 11, 2005 1:21 pm
first of all, if you dont have a multimeter, buy or borrow one. you will need it. the yellow wire you wont be using. its an optional output, to send the warning to another unit (or to toggle something, i cant tell.) look through your FSM and find the wiring diagram for the ignition harness (this is where i would prbably wire it, its out of the way yet not far from your A pillar.) find the wire that has 12v at all times (probably labeled as simply 12v, or battery). test it with the meter with the key off, then on just to make sure it has 12v at all times. splice, solder and tape it. the orange wire will go to a 12v "switched" wire, a wire with 12 volts ONLY when the key is on. try searching for the actual ignition wire in the harness. if you have a drill at home, i would get a self tapping screw and drill a ground for it, but its not necessary. you could just splice it into an existing ground. as for the white wire, there are a few ways you could do this. most cars have an actual illumination wire, this would be optimal because then the gauge light would only be on when the dash is illuminated. you can also find the headlight switch in your wiring diagram and find the wire that sends power to the headlights when they are turned on, so the gauge will only light up when the headlights are on. and if for some reason you want it to always be illuminated, hook it up to that ignition wire so its on whenever the key is. hope this helps, and good luck!
