GREDDY VSPL QUESTION?
NisanS13turbo
Car: Diamond White 91 Nissan Coupe
I've searched but found nothing, the right greddy pipe has a flange sticking out. What the hell is that for? a bov?
180fan
Car: 89 fastback
the one on the passenger side? if you're talking about the one on the driver side, it should be for the wastegate actuator
kassed33
Car: 95 S14
If your talking about the pipe that goes from the IC to the intake manifold, the part that sticks out is suppose to be for the Recirculation valve to connect to that the Stock Sr20's have, but most people dont use them they use a BOV instead so you can either plug it up or do as i did and put my BOV on it, i TIG welded the mounting collar for my HKS SSQV to it then just put it on there.
