Greddy Type S bov...
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
Where can i get a replacement INNER spring for this bov..??
I removed mine to modify it as a compressor bypass to run recirculation setup... But now i got the dec-air feature to work so that i can run open bov and it works great.
The problem is the bov leaks under idle unless i tighten up the valve all the way... Then it seals and there is no leak... BUT, it wont open when i shift thru the gears even under a full 10 psi run... Its all compressor surge..
