HPR »
https://forums.nicoclub.com/hpr-u46259.html
Sun Aug 05, 2007 10:57 am
Take off your underdash panel and connect straight to the ignition harness. 12V+ is white, IGN is black/red, ACC is blue. If you're going to hook up the speed sensor and ebrake, you can find ebrake at that BIG plug up in the driver kick panel, it's the only yellow/purple on that plug (or you can go straight to your handbrake). The speed sensor is yellow/green at the ECU.
