greddy turbo kit
kamikazestorm420
i haf a 1991 240 and i was wondering if the 95-98 240 greddy turbo kit will fit into a 1991.
if so do u need to do any modifications in the engine bay?
Nurv
Car: performance engineering, rc cars, beer, tits
kamikazestorm420 wrote:i haf a 1991 240 and i was wondering if the 95-98 240 greddy turbo kit will fit into a 1991.
Try searching for it because I believe this topic has been discussed before...The kit was designed for the OBD-II KA24DE I believe. Just minor trimming around there assuming it was design for the s14 chassis. Good luck
C-Kwik
The downpipe will not fit. It will either require that you have an additional piece made to extend it all th way to teh cataytic converter, or make a whole new downpipe. Some modification may be necessary to fit the smog equipment as well. Most everything else will probably fit with little to no modification. The E-Manage used to alter the fuel and timing will be an issue. Greddy didn't design it with a US Spec S13 in mind. You can make it work, but you will not have the advantage the MAF being a listed item. So you will not be able to swap out the MAF to another listed MAF with ease. And I don't know if the preprogramming will work with the S13 very well. You may have to reset it and start from scratch.
Dougster
Car: Fun fast cars!
Interesting...I am thinking of the Turbo kit for mine too...
S13ChucKAT
Car: asd
for a SOHC?... Ive been researching.. for around 2200, you can get a T3/t4 turbo kit.. minus intercooler..
http://www.gladmanperformance.com/
Dougster
Car: Fun fast cars!
Hmmmm? I see they have a video clip of a KA24DE-T but no info on the DOHC Turbo kit?
S13ChucKAT
Car: asd
where?... on gladmanpreformance.. thats the SOHC turbo kit..
