extreme135 »
https://forums.nicoclub.com/extreme135-u47620.html
Sat Sep 22, 2007 11:46 am
There is no exact hp number for any turbo kit, it all depends on the application/engine with what mods are done before being turbocharged, what shape your engine is in, your compression, and most of all what psi you are running on whichever turbo kit you buy, as far as the greddy kiy is concerned it comes only with 370cc injectors which at 320hp would be over maxing the out, with a stockengine as yours with good compession on the TD06 you could probably run about 10-12 psi max on 370cc inj. which would put you around 230-260 hp and also the greddy log manifold is very restrictive, you are better off putting the 3K you will spend on the greddy kit and build your own kit, get you something like a ground zero manifold, garrett T3/4 50 trim turbo, some at least 550cc inj. a enalthapy or JWT tuned ecu, get your own intercooler piping made or buy a full kit a walboro 255lph FP, your oil feed line and outlet for your turbo, and you will save money and be able to make 320hp+
