Viperjunkie »
https://forums.nicoclub.com/viperjunkie-u92367.html
Mon Mar 08, 2010 5:28 am
The installation is pretty self explanatory. But no, the adapter piece is only for the 3.5.
If you follow your stock exhaust, you'll see where it meets the cat near the front of your car. Unbolt it from there and start pulling the exhaust off the rubber hangers.
Make sure when you're installing the exhaust to use some WD-40 to lube up the rubber hangers, so the exhaust wont be such a pain to install.
This is coming from over a year ago when i installed mine so i might have forgotten a step. But email me if you have anymore questions.
Good Luck!
