sshhh!Emperor_Tha wrote:Damn that 18g is sick
Yes if you read, I said I clocked it to move the turbo inlet side some so that it wasn't hitting the bottom of the manifold.Kalypso123 wrote:you should be able to fit it no problem.
if the center section is attached to the turbine housing via V-band you can rotate the whole thing, simply by loosening it. it looks that easy to me
dump pipe: not a problem.
wastegate, dont sweat it. you should replace it with an HKS anyway
gt2871r .64 is a champion turbo, it really cant be beat. the gt28rs is also nice. but this one doesnt look bad - did you check the compressor map? give me first dibs if you decide not to use it. [email protected]
it looks to me like your correct, from the picture, i think that the compressor housing is held on via a large snap ring.Kalypso123 wrote:yes but what im implying is can you rotate the compressor, the center section, and turbine housings independently of each other?
it seems like it can be separated into the three sections. then the turbine sits against the manifold the center now has its feed going up and down. and the compressor's inlet point however you want. am I making sense?
Yes I am going to check that when I get home. I loosened the snap ring and moved the intake side of the turbo to clock the snout down from hitting the manifold. But I did not think to try the other side, thinking that it maybe in three pieces. I will try that when I get home.Kalypso123 wrote:yes but what im implying is can you rotate the compressor, the center section, and turbine housings independently of each other?
see!? I can read you can pro'ly remove both sides and rotate them as you please.dogg4217 wrote:I loosened the snap ring and moved the intake side of the turbo to clock the snout down from hitting the manifold. But I did not think to try the other side, thinking that it maybe in three pieces. I will try that when I get home.
Maybe this turbo will work
I love the ingenuityJadesr20det wrote:i would say if your not going to tune it slap a t25 back on it....the temptation is too great....the mitsu turbos are sicknasty as im putting a 20g on my sr
there are a lot of very nice - underrated turbos that are affordable and well built.
borgwarner/KKK k27.2 holset HX35
are two others,
