greddy solenoid harness for profec e-01
virus77
Car: 95 S14, 71 240z, 97 e320
Im missing my greddy solenoid harness for profec e-01, the harness that connects the boost controller solenoid to the e-01 main unit, and i dont think that they offer a replacement. first off if anyone for some reason has one, i would but it, but this is unlikely that someone has it soooo
the solenoid has some thick gauge red and black wire leaving it. and teh connection on the unit has two spots repectively but in a connector format with prongs. if i were to connect two wire to teh solenoid wires and run them to the unit and plug it in with crimp on connectors you think it would be fine, granted i get the positive and negative connection right. Is there any way i could find out for sure which connector on the main unit is supposed to take negative or positive. If anyone has one and can check where the red or black wire on the solenoid eventually connects to the main unit (meaning left or right prong while looking at teh unit dead on) id appreciate it. I hope i could figure this out and not waste a E-01
also the greddy site is down, anyone have their number.
virus77
I talked to mohdparts and he is pretty experianced with these products and this is what he had to say, anyone think he is wrong or does this sound right.
"you can makethe wires yourself, they are only 2 wires, order doesn't even matter its a simple on/off circuit, it wont matter which side you place the wires, youcan even connect your solenoid to your battery for split second testing and youwill notice that it operates no matter how the wire are hooked up to thebattery..."
huguetpj
Car: 93 KAT Coupe
He is right. Solenoids don't care (most of them that is) how the current will flow. And in this particular case this one does it won't hurt it. Just test it as he says to make sure it si opening and closing.
