GTS »
https://forums.nicoclub.com/gts-u37071.html
Tue Jul 01, 2008 5:56 pm
I have the Greddy setup, so I will chime in.
No BOV is necessary at the 5.5lbs of boost that Greddy kit tuned it for. In addition, the wastegate does its job quite well.
Later, you will want to add a wideband to monitor your AFR. Personally, I went with the AEM wideband.
You'll probably want a boost controller/gauge as well. I stuck with AEM and got the AEM Tru Boost unit. It serves as a controller and a gauge. It is very easy to use. It doesn't have the fine tuning capabilities of more expensive units, but for a 80% daily, 20% tracking car, it does the job just fine. It also matches the UEGO quite well.
But for your next round of installs, I would highly recommend wideband, controller and a BOV to complete your setup.
It is a very bad idea to turn up the boost without a BOV to relieve the pressure.
The Greddy tune is very conservative. At WOT, the AFR is pegged at 10.
Again, this was my personal preference, but I didn't feel the need to add any other gauges except for wideband and boost.
But instead of opting for the manual transmission swap, I decided to stay automatic for 2 reasons; firstly, the transmission is find and very strong up to 300hp. Secondly, constant boost without losing boost between shifts is quite awesome as well. But again...these are just my choices.
