Greddy RS valve on the SR
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
I think im going to buy the Greddy RS BOV.Because they are so easy to route back to the intake.Are any of you running this BOV on your sr's??How do you like them,how do they sound.Is this a good BOV to get??Im running a stock valve now.Let me what ya think.
twofourzeroSX
Car: 91 sileighty
i have the RS on my blacktop...just finished the swap 2 weeks ago. I am only running 7psi right not, and you can definetly tell the BOV was designed for much more. It doesnt just flap open but chatters due to the low boost... its like a tshh tsh tsh tsh... idk i cant really type sounds...but anyway i love it, get it!
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
i had it on mine for about a month, i like it. i suggest getting it.
compression
A bov is a bov. they are so simple that is hard for a manufacturer to screw it up. Coming from GReddy you know it is going to be descent. I have one and i run about 16psi, dumping to atmosphere and it works fine. NO complaints.
Silverbullet91
Car: 1991 240SX SE Coupe w/sr20det redtop
I've got one on my sr. I don't have any complaints about it. But to be honest I don't have a lot to compare it to. I'd go for it.
D1 guy
Car: 1997 kouki S14 SR powered w/400whp and a stock 1994 FD R2 (26,000miles),
I have a greddy rs vented to atmosphere. Works great and sounds insane blowing out 20psi. I love it. I suggest buying it b/c it sounds a lot more agressive than the type s. My favorite bov is the hks ssq though. That sound is amazing....you know, the sound of a seal getting clubed to death. Either one is great though.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
D1 guy wrote:I have a greddy rs vented to atmosphere. Works great and sounds insane blowing out 20psi. I love it. I suggest buying it b/c it sounds a lot more agressive than the type s. My favorite bov is the hks ssq though. That sound is amazing....you know, the sound of a seal getting clubed to death. Either one is great though.
Quote of the day
Neil
Car: shooting laser guns
twofourzeroSX wrote:i have the RS on my blacktop...just finished the swap 2 weeks ago. I am only running 7psi right not, and you can definetly tell the BOV was designed for much more. It doesnt just flap open but chatters due to the low boost... its like a tshh tsh tsh tsh... idk i cant really type sounds...but anyway i love it, get it!
Is it like a pretty rapid fluttering sound, like "Chiffchiffchiffchiffchiff" ?
You certain that's not compressor surge? maybe the BOV is adjusted to only open at a range somewhere above 7psi
95lstegman
Car: 1989 570SX, 2005 Acura RSX, 1994 Toyota Corolla
Neil wrote:Is it like a pretty rapid fluttering sound, like "Chiffchiffchiffchiffchiff" ?
that's EXACTLY what i was thinking.
you guys really need to check out the abilities of a BOV before you pick one. somebody mentioned the SSQV, which is simply designed to be loud. it also happens to have about the WORST compressor surge on the market. the VERY best designs to combat compressor surge come from the OEMs, like Mitsubishi and Nissan. problem is they can't hold much boost. if you're running a stock or any other wet floating bearing type turbo, you really need to find a valve that offers nearly 0 compressor surge. and if you're at stock boost, stick with stock. it's almost the best out there, and you already have it and it's cheap if you don't. Sport Compact Car did a nice article on BOV's a while back, try sportcompactcarweb.com and see if it's there. the GReddy Type-S scored the best for aftermarket valves @ about 17psi if i remember correctly, and the SSQV had about as much surge as not even having a BOV. can we say "bye-bye, non-BB turbos?"
PAsrfreak
Car: 95 240sx SE
the rs is the best sounding blow off valve on the market, imho, but only if you dont like the squeaking noise that half the other ones on the market make. some people like the squeak
Neil
yea i heard your mom likes the squeak
I bought the Greddy RS, also have the stock bypass valve. If I hear surge on the RS's lowest setting I'll remove it till I turn up the bewst.
