Greddy rocker arm stoppers??????
Greddy323
Car: 240sx s13
Are they easy to put in and are they a good upgrade?????
Emperor_Tha
yea less than 20 mins
take out valve cover and coil packon the p/s rocker arm....move all the outer rocker arm bolts they are 10mm. put in one of the ras in tighten the bolts. use a 1/4 inch rachet and just tighten it. proper way is torque it 8lbs. then on the driver side loosen the outer bolts and remove the oil splash shield. install the ras then tighten bolts.....put every thing back together...
Greddy323
Car: 240sx s13
thanks....also do you have to do a 5 lug conversion to do the z32 big brake calipers??
mistamacadamian
Car: s13
Greddy323 wrote:thanks....also do you have to do a 5 lug conversion to do the z32 big brake calipers??
wow some one did their research...but no you dont mr greddy323. and rocker arm stoppers are over rated. floor it till your at 7k in 3rd and drop it in 2nd.
Greddy323
Car: 240sx s13
i have not done any research just know from experience im just asking some simple ?'s im 18 just learning all i can
Emperor_Tha
No, ebay sell 4/5 lug rotor for the 300zx caliper. Only problem is finding the offset for the rim with 4 lug to clear the caliper. Or else u have to run a hubcentic in the front.
I don't think u can do a 300zx rear brake upgrade becuz of the ebrake.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Please do some searching. These are both easy topics and have been covered before. You'll find a lot of information at the tech section in the drop down menu at the top of the page
