240sxed wrote:As far as using stock things, can it use stock injectors, throttlebody and vacume lines/hoses as well as the iacv valve?
As far as the Q45 TB, do you need anything to make that work? Do you use the Q45 TPS and it just works as far as voltage and everything, or do you have to get something to compensate like a z32 maf. Or, do you simply just use the tps from the Rb25 in the q45 tb?cvc9216 wrote:Yes it's a full manifold and uses all the stock parts. pretty much comes with everything you need
EDIT: forgot, you need an adapter to use the stock TB. It's designed for the Q45 TB
Does the Q45 throttle body vary with years? I know that the q45 uses 2 different ignitor chips for their different years, so Im wondering if the throttle body is any different?eh? wrote:IF you have a SI Rb25 you can just plug in the Q45 TPS, if you have a SII you have to splice the wires.
