Greddy RAS Question
Hijacker
Car: '92 240sx Convertible
'94 F-150
I just got my Trust Rocker Arm Stoppers today and reading through the instructions, it states that the number two cam cap on the exhaust cam should have its baffle plate removed. is this correct? I usually don't question instructions, but since these are in japanese, I just want to double check before I pulla bone headed move on a mistranslation
soflajdm
i believe that's correct... otherwise, it wont fit
Hijacker
'94 F-150
that's what i thought. thanks!
180fan
Car: 89 fastback
you can keep it if you want, use tin snips on the sides. I've the tomei ras and it says to keep the baffle there. After checking tomei's sr20det buildup manual I saw they just used some tin snips and put it under the oil lines and over the ras. Might wanna try that if you want to keep the baffle there.
Hijacker
'94 F-150
everything's bolted back up and i'm too lazy to pull it back apart. I did clean it up and baggy it in case I ever want to put it back on. All it looks like it does is keep the oil away from the seperator
