greddy profec not the usual problems..
beatlust
my display when in regular boosgt mode goes from negative (as it should i guess) up pretty quickly as i give it revs. the problem is when i go from negative to zero it just stays at zero..??? its boosting because i hear the turbo and its making power..what could this be? the display doesnt read my boost levels once i reach zero??
does anyone have a good thread to share for tuning one of these? i want 9psi lo/ 11-12 hi boost. i have the supporting mods for higher boost; fmic, exhaust, intake..anyone have some good numbers i can use? i certainly dont want to blow ish from running the POs previous settings.. i bought mine on ebay and im thinking the user had it on a dsm so it certainly needs tweaked.. i have searched but all the threads dont really give any decent info. thanks in advance..
beatlust
anybody pleaasseee?
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
Double check to see that the vac lines are plugged into the correct spots and that the unit is hooked up to the fpr as the manual says.
