Greddy profec e-01??
lilskyline240
Car: 90 240sx w/ rb30det
does anyone have experience with this boost controller?? cuz i was lookin to buy one and ive done some research on different ones...but im just gunna ask around to see if anyone has one and how they like it....so let me know pros and cons of it plz....
lilskyline
SillyRB
Easy to use need the additional harness to connect.
A buddy of mine is selling one the E0-1, with the harness and the remote Switch, everything in the BOX for $400
virus77
Car: 95 S14, 71 240z, 97 e320
I like it alot, its easy to use and has a nice display that I use for my wideband. I also tune my emanage with it so thats a big reason why I got it.
lilskyline240
SillyRB wrote:Easy to use need the additional harness to connect.
so your sayin that if i would buy the EO-1 online, i would have to order the harness with it?? cuz it dont come with it?? how easy was it to install??
Email me about the one ur buddy is selling [email protected]
Carl H
virus77 wrote:I like it alot, its easy to use and has a nice display that I use for my wideband. I also tune my emanage with it so thats a big reason why I got it.
hehehe, great minds think alike eh?i ran my tech edge 2a0 wideband into the e-01's analog input and use it to display the afr on it.......works quite well really.not to mention i can datalog runs with the e-01 and see what afrs are what and where, very useful for tweaking.its a good controler for boost, but the fuzzylogic bit can be a bit iffy sometimes, however the manual mode is the shizit and will hold boost rock steady when its set right.also by running the wideband into the boost controler i can have it cut boost if the afr's go too lean (well cut boost higher than the gate).i like it alot and its fairly easy to use and setup, its nice having the afr,boost,and tach all in one unit.
virus77
Oh yeah the auto boost setting isnt too great, use the manual settings and it will hold boost like no ones business. It really does have some nice features like mentioned above. It lets you hold the wastegate signal more as the rpm's rise so you hold boost steady to redline in case you are loosing 1-2 psi near the upper rev range.
lilskyline240
Well i havent heard anything but good things about this set up....how hard was it to install??
lilskyline240
Carl H wrote:hehehe, great minds think alike eh?i ran my tech edge 2a0 wideband into the e-01's analog input and use it to display the afr on it.......works quite well really.not to mention i can datalog runs with the e-01 and see what afrs are what and where, very useful for tweaking.its a good controler for boost, but the fuzzylogic bit can be a bit iffy sometimes, however the manual mode is the shizit and will hold boost rock steady when its set right.also by running the wideband into the boost controler i can have it cut boost if the afr's go too lean (well cut boost higher than the gate).i like it alot and its fairly easy to use and setup, its nice having the afr,boost,and tach all in one unit.
would this wideband work with the E-01??http://cgi.ebay.com/ebaymotors...wItem
if so, would that be a wise investment?
Carl H
if it can output the afr's in 0-5v scaling then it should be mint.
lilskyline240
sweet....i think ill go with this set up then....how easily did u tune it??
