fabio420 wrote:The prfec b has 3 attachments in the back. 2 are electrical, and one is the boost source. They all have to be connected. The vacuum source is what the boost controler uses to guide the percentage increase in boost. I just plugged mine in 4 days ago, so hit me up if you have any more questions on install ar programming(It can be a little tricky)
That nipple was already hooked up to a vac / boost source.. I thought it was there just so that we could have a boost reading from it in case we didnt have a separate boost gauge...
So i went ahead and removed that line from the unit... Well i guess ill be hooking it back up...
Thanks
