greddy profec b spec II question ! / help!
Eli
Car: 1995 240sx
hey to all with the greddy profec b boost controller just wondering what your set %, gain %, start boost, warning, and limiter is set at. also a brief description of your setup.
I just started to play around with my profec but i do not want to overboost however so far my peak is at 8.4 psi (which is low) however my set % is at like 15%. I want to run atleast 9.5 to 10 psi. I have a basically stock setup (exhaust, bov, 3"dp).
also what is the idle vacum reading supposed to be at? mine reads like -90 around. thanks
f150intally
Here are my settings, i'm running in PSI mode.
Low: set boost 20-24 depending on the weather yields 10.5lbs., gain% 10, start boost 9.0lbs. warning 12.0lbs, limiter 16%
High: set boost 38-40 yields 14.5-14.7lbs, gain% 10, start boost 13.0, warning 15.8, limiter 32%
Do not mess with the gain. leave it at the factory default of 10% for both high and low boost.
my vacuum is the same as yours.
Eli
Car: 1995 240sx
^thanks man!
f150intally
no prob, just let me know how yours works out.
