BlazedGlory »
https://forums.nicoclub.com/blazedglory-u6480.html
Mon Aug 28, 2006 12:32 pm
Well don't I feel like the village idiot... I kept searching and reading and reinspecting vacuum diagrams and whatnot... A guy I work with (who has been working on cars [not necessarily performance] for a very long time) was checking it out and told me I should try the NO port instead of the NC port. I kept ***** footing around and tried to tell him that was how you hose up the stock actuator, but not external wastegate... After he examined the diagrams himself and finally believed me, he decided to check power to the solenoid. I unplugged the harness to the solenoid and showed him where it was. He said, "why am I always pointing out your stupid ****?" as he held up the harness for me to see that the green wire had come out of the plug...
After battling with the plug trying to get the clip out to re-crimp the wire in there, I finally submitted, cut off the plug(s) and hardwired it together...
It is amazing how much better a solenoid works when it actually has power . The thing spools about 1000rpms quicker (and I was starting to worry), and it was confirmed that the wastegate I purchased actually had an 11psi spring in it. I guess if you hook everything up to an unpowered solenoid it will drop the boost a bit haha (was running about 8.5psi or something). At first I had the "set" setting at about 15 before I realized that was putting it up to 15+psi... I didn't get to mess with it much because of the rain, but I plan on running it around 12psi or so for now until I get used to how it is actually supposed to feel!
