GReddy Profec-B Install
badass240sx
I've looked for a walk thru or some kind of good write up for the install but haven't been able to find anything that great at all. So call me stupid, but I just got my Profec-B in today and will be installing it this weekend after this hellish work week, lol. Anyway, my current setup has a vacum line running from the wastegate to the chargepipe (i/c pipe) and another from the BOV to the intake mani. So how should I run the two hoses and do you still "T" off the fuel pressure regulator with the profec-b? I would assume you would also have to "T" off the line from the BOV to the wastegate? I really have no clue and would appreciate any help from you guys :)
BTW, this is on an S14 SR20DET.
S13240
You're gonna have to T one vacuum line from the boost gauge/fpr vacuum and T one from the wastegate signal line.
badass240sx
I was thinking of just running a new hose from the chargepipe into the "IN" section of the controller then another from the wastegate to the "OUT" section of the controller. Lastly, T off the fpr for the boost signal. This should work, eh?
S13240
You are going to have to run new hoses anyway. Same basic concept...didn't your boost controller have an install manual with all the things you need to install?
badass240sx
It came with everything but instructions, unless I just so happen to know Japanese and not know about it, lol. The pictures gave me a good idea, just want to confirm the way im doing it will work; not really concerned about the hoses, no idea why I mentioned 'new' hoses, of course they are new. So will my setup work or no?
S13240
One thing I forgot to ask...do you just have the regular profec b or profec b spec II? I have the spec II so it may be a bit different if not at all.
I'll take a look at mine tomorrow morning and I'll let you know how mine is hooked up.
