Greddy profec B help!
Eli
Car: 1995 240sx
hey to all with the greddy profec b boost controller just wondering what your set %, gain %, start boost, warning, and limiter is set at. also a brief description of your setup.
I just started to play around with my profec but i do not want to overboost however so far my peak is at 8.4 psi (which is low) however my set % is at like 15%. I want to run atleast 9.5 to 10 psi. I have a basically stock setup (exhaust, bov, 3"dp).
also what is the idle vacum reading supposed to be at? mine reads like -90 around. thanks
runyun
Here's a good one:http://forums.freshalloy.com/u...art=1
I found another one that was really good, which I use.. but I can't find that link.
But my low boost is at 10psi and high is at 14psi (there is a .5 variance depending on temp, high boost, etc)
I can check mine later if you need it... but boost holds consistantly :D
runyun
oh, if you don't have a fmic, it's recommended you dont go over 10lbs.
my setup:fmic, bov, air filter, dp, exhaust
