Greddy pressure sensor, how accurate?
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
So the pressure sensor “replaces” the stock MAF, grate…
I am wondering how accurate it is.
And do I still need to run my stock maf, if not, how do I avoid error codes, or does the e-manage take care of that?
Lastly my instincts tell me I should place it right before the TB, true?
Red-KAT
Car: 1995 240sx-se ka24det
In the book it sez thats its for use when your car runs out of range of the MAF or MAP... I'm not sure if it can replace the whole thing...
Checkered-Member
^ i know....I’ll have to call greddy about that.
I think its a grate deal, 100 bucks for a new "maf" rather then spending 100+ on a used maf and wiring it somehow, while this is plug and play
MikeMurphy
Car: Guess
call greddy and post the response on here please.
Checkered-Member
This is what I found out:
The pressure sensor goes right before the TB
It doesn't replace the MAF, the ECU will continue to read from the MAF but e-manage will read from the pressure sensor.
In other words the e-manage will ignore the maf, you still need to run it to avoid error codes.
huguetpj
Car: 93 KAT Coupe
Checkered-Member wrote:The pressure sensor goes right before the TB
BEFORE the TB, why?
Red-KAT
Yeah that seams kinda weard before the TB...
They have a cord that goes between your E-01 and E-manage to use the same boost signal, off the FPR... That way you dont need to spend the extra $120 if you have the E-01... I sent mine back.
Checkered-Member
^^^^ You guys are slow
TB = Throttle Body
What did you think it was?
MikeMurphy
Car: Guess
huguetpj wrote:BEFORE the TB, why?
I would assume because it only reads positive pressure, which makes sense since its used in conjunction with the MAFS.
Checkered-Member
MikeMurphy wrote:I would assume because it only reads positive pressure, which makes sense since its used in conjunction with the MAFS.
And it can only be used with turbo or supercharger
fiznat
Car: Grown up :(
Checkered-Member wrote:In other words the e-manage will ignore the maf, you still need to run it to avoid error codes.
Are you SURE about that? I did a *lot* of reading about the e-manage and how it works, and from what I understand, it still reads outputs from the MAFS, but uses the pressure sensor to expand the range/resolution of the map- so that you can tune more accurately and to larger dimensions. I'm REALLY not sure that it actually allows you to "forget about" buying a bigger MAFS...
Checkered-Member
fiznat wrote:but uses the pressure sensor to expand the range/resolution of the map- so that you can tune more accurately and to larger dimensions. I'm REALLY not sure that it actually allows you to "forget about" buying a bigger MAFS...
Quote »use this sensor to scale the map table, this is used when the factory system exceeds maf or map limit, best used with turbo or supercharged engines[/quote]key words: factory system exceeds maf so when the stock maf is maxed out, the pressure sensor takes over, or the e-manage ignores it, I don’t think the e-manage will read both sencors and "choose one"
huguetpj
Car: 93 KAT Coupe
That could be it
fiznat
Car: Grown up :(
oh okay gotcha, it ignores the MAFS once you've exceeded the factory MAFS' capabilities. Thats actually pretty sweet- save yourself sourcing and buying a Z32 MAFS.. Although still, everyone I know who has the e-manage uses a bigger MAFS AND a pressure sensor.
Does the e-manage software list the stock S13 MAFS?
